aluminum accumulators vs pinless ones?
So I purchased from Ebay two items.
FORWARD CLUTCH ALUMINUM ACCUMULATOR PISTON
As well as a:
1-2 ALUMINUM ACCUMULATOR PISTON SMALL PIN
How do these differ from the Pinless ones I see from here:
77987-02K 4L60E Pinless Forward Accumulator Piston
And this:
77998-03K 700R4, 4L60E 1-2, 3-4 Pinless Accumulator Piston Kit
Being that I purchased at least aluminum versions to replace the plastic ones in the tranny, am I losing anything by sticking with these units vs the pinless ones?
As well as a:
And this:
No, you are not losing anything by sticking with the pinned ones.
The pinless ones were designed for worn acc. bodys. They are self centering, using 2 seals.
The pinned ones use the pin to center them, and only have 1 seal.
You will be fine with the ones you bought.
BigKID
09-22-2015 09:59 PM
34, 4l60e, 700r4, 7799802k, accumaltor, accumulator, accumulators, aluminum, forward, fwd, pinless, piston, transmission
