another 4l60e down! R.I.P 4l80e swap questings
Another thing, I highly doubt you’ll have to shorten the driveshaft! The 80e is actually very close to 60e length. There’s three diffrent slip yokes for the 80e, sobyoure good with your stock length driveshaft! Only thing you’re gonna need to do is install a bastard u joint, 1350 on the 80e yoke side and whatever the 60e driveshaft side is. Pretty common u joint at any driveshaft place.
BOOsted, thanks I actually have two different length yokes one like 7.75 long the other is 8.75 inch long be cool to save some money and not have to shorten the DS
For the crossmember, dirtackracer here sells them - great quality...used one with my swap. As stated, same dipstick - different tube & get the right yoke and you won't need to modify the DS. You won't regret the swap once done. HUGE piece of mind...
for now im just going to mod my crossmember trying to keep cost down this was not planed, 2 weeks before this the timing chain on my zo6 let go at 6800rpm so between the timing chain and now the trans "fun $$" is thin
hunting down the flexplate spacer, sensor plug & dip stick tube found a local guy that parts out 2500's while i was there picked the dual exhaust pipes and passenger side manifold from a 6.0 (for $60) so will be converting to true dual catless exhaust in the processes, when i came home my son and i removed that trans getting the exhaust off was a PITA took about 2.5 hours to get the 6 nuts off
what is the right slip yoke?
Since I already had 1350s on my Dennys D'S I bought my slip yoke from their store. They have every conceivable size and configuration you might need. Does the shaft have a hole in the center of it?
