Any tips or tricks for removing leaf spring bushings?
I used a torch for the inner part then a sawz-all to cut out the outer most layer of steel that's pressed in the leaf. I did that so I made sure I didn't cut into my leaf. Made a single cut across the got a flat head and tapped under the edge and bent up the edge and then it tapped right out.
signguy62
07-27-2015 03:42 PM
