any way to add back an inch after usning flip kit?
#23
11 Second Hall Moniter
You guys are over-thinking the add-a-leaf. It will add arch to the leaf spring(and increase load carrying capacity). The added arch will move the axle farther away from the frame. Now, unless both of my ex-wives are right & I actually am a dumbass, the rear of the truck will sit higher than it did before the add-a-leaf was installed. Do I need to search google for pictures to help explain this?
#24
#25
Well, it really doesn't matter how big you type. You are incorrect.
Take a look at this example. Adding the leaf below the axle, and below the main leaf, will not put the axle closer to the frame. It will add arch to the spring assembly, and move the axle farther away from the frame. That will lift the rear of the truck.
C'mon guys, this is pretty simple stuff here....
#27
5 year bitches!
some ppl are just net repeaters like the two above at the top. for years ppl have lifted trucks using AAL. they dont do it for lowering purposes, they do it for lifts. My s10 had a AAL and i gained about 1.5" of height
