any way to add back an inch after usning flip kit?
Old 08-15-2010, 10:13 AM
  #31
5 year bitches!
Quik's Avatar
Originally Posted by 00ChevyScott
Who's "repeating" off the net. If we did that we'd post that it lifted the truck then since evidently that's right?
I figured it would drop the truck as much as the added arch would lift it and it would probably even out. Apparently I'm wrong.
you post info that is incorrect more then one time. You give false info, saying a AAL is going to lower you is incorrect. Its a cheap way of lifting your truck and has been for ages. trying to defend this point to others so you dont look dumb is pointless. AAL adds height reguardless if its under axle or over axle. just like removing a leaf lowers the truck, adding one raises it
Old 08-15-2010, 11:09 AM
  #32
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
Adding a stock leaf like was posted will not raise the truck, the AAL thing came up later which I agree would lift the truck depending on how big a AAL you use.
Old 08-15-2010, 11:11 AM
  #33
5 year bitches!
Quik's Avatar
cody i used a stock set of leafs and i gained height on my s10. it has a stock over axle.
Old 08-15-2010, 11:14 AM
  #34
1slow01Z71's Avatar
Which side did you put the leafs on?
Old 08-15-2010, 11:17 AM
  #35
5 year bitches!
Quik's Avatar
the additional as added towards the top of the pack. the leafs on a s10 are under the axle same as how they are in a flip kit for a silverado.
AAL is same as any leaf being added
Old 08-15-2010, 11:22 AM
  #36
1slow01Z71's Avatar
I know my first truck was an 02 s10, AAL are different than stock leafs. The AAL has a LOT more arch to it and I could see that lifting the rear end when added between two stock leafs.
I was thinking he was talking about adding an additional leaf on TOP of the original main leaf which would drop the truck, I can see it raising the truck if youre talking about adding the new leaf in between the spring pack.
Old 08-15-2010, 11:26 AM
  #37
5 year bitches!
Quik's Avatar
also by using another leaf you gain load limit so youll gain height just from that.
Old 08-15-2010, 04:04 PM
  #38
KleenHall's Avatar
a stock leaf WILL raise the truck, how much is dependant on the thickness of the leaf, length and the arch it has
what is wrong with some people...wow
this would be the same as adding a block, AAL's always go IN the pack, not on top
GMCSIERRA5.3
08-07-2015 01:50 AM
kkirwan71
07-28-2015 06:39 PM
iregret
07-27-2015 10:31 PM
121
07-16-2015 12:18 AM
Quick Reply: any way to add back an inch after usning flip kit?
