Anybody with hotchkis suspenion...
10 Second Truck Club
I have 2" springs in the front and 4" springs in back. I want alittle more drop in the back. I was considering using a 2" drop shackle. If it gets to low in back I would probably go with 1" drop lower control arms as well in the front.
Just wondering if someone else has done this with success... if I do I would probably have to change the pinion angle a little.
Yeah, you'd need a notch if you went any lower out back. Also, I think someone out there makes a 1" drop shackle if you're concerned about it being too low with the regular 2" drop shackle.
Personally, I'd use a drop spindle before a drop control arm any day of the week, but all the drop spindles I've seen only come in the 2" variety.
Ok, Thanks, I'm going to do some measuring and find out what I can get to match the amount I want to drop...already have a c-notch...appreciate the comments .
mine is an ecsb but i have 3" eibach springs in the front, 4" springs in the back with 2" shackles and aftermarket overloads strapped to the top with a c-notch for about a 3/5 drop but i have never changed the pinion angle.
mine is all peiced together because i lowered it 3 times until i got it to where it is now (and i still want to go lower)
i have 4" hotchkis leaf springs in the back... and it was to high.... so i dropped it one more inch using the 1" mark on my 2" shackles then i put caltracs on and it lifted the back up more so now i have it on the 2" mark of the shackles... shes all good now.. so i have a 2/6 drop... and my frame sits about 1 inch from the axle.. but the caltracs make the back so stiff it doesnt hit.. unless i put 4-500 lbs back there...
the picture in my sig doesnt do it justice its lower than that.. but yea.. i need a C-notch
MarineBlue03GMC
10-21-2002 02:25 AM
