anybody lower their truck lime this ?
That drop is far less problematic than you make it out to be. What drop are you running? No doubt that truck has a custom step notch, none of the bolt in ones will give enough room for the axle with that much drop. The real issue is the clearance at the transmission crossmember as it's the lowest section of frame. A custom x-member would pretty much solve that. Avoid speedbumps and it's all good.
truck rides great actually.
