Anybody strip a converter bolt?
Old 12-16-2006, 10:27 AM
14 Second Truck Club
I'm fixing to try and get some vice grips around it.
Old 12-16-2006, 12:08 PM
Bolt is officially stripped. Got the other one out though. Vise grips didn't work. I even tried hammering the hex-bit in, thought I almost had it and it stripped.
Old 12-16-2006, 03:31 PM
I borrowed my g/f's dad's air compressor and air chisel. It barely made an indention on it and I've been at it for 30 min and basically rounded off 2 chisels already.
Old 12-16-2006, 03:36 PM
twobit's Avatar
try a regular chisel and a big f"n hammer. Sharpen the chisel with a grinder every few minutes. I used an air chisel on the ball joint rivets and it didnt do much either. I then used a fat chisel and a big hammer and that seemed to work better. Its gonna be hard to do being your in such a tight place.
Old 12-16-2006, 03:55 PM
Thanks Clint, I'll try it.
Old 12-16-2006, 04:00 PM
Do ya'll think it would hard to pull the motor out with the tranny?
Old 12-16-2006, 04:37 PM
onebadrubi's Avatar
can be done. I think someone did a write up on that not to long ago.
Old 12-16-2006, 04:54 PM
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
In a 2wd its cake, you can do it pretty easily just need an extra person to help guide the trans once you get the engine off it mounts.
Old 12-16-2006, 05:09 PM
Sexy Party Mod
FarmerBeau's Avatar
pm thunder550. I know he pulled his engine and tranny as one unit.
Old 12-16-2006, 05:22 PM
Resident Retard
BlackGMC's Avatar
Use a SawZaw and just cut the head off of it then worry about it once it is out. If you don't have a SawZaw use a hack saw blade. Might take awhile thou....
Quick Reply: Anybody strip a converter bolt?
