Anybody strip a converter bolt?
Old 12-16-2006, 05:22 PM
  #21
onebadrubi's Avatar
yah it was thunder, he has pictures and a small writeup AND he is 4x4.
Old 12-16-2006, 05:40 PM
  #22
02sierraz71_5.3's Avatar
just weld a small handle on it or use a reverse drill bit
craftsman has a set of easy offs that fit over the head and work like a champ they are worth thier weight in gold I would try them first
Id only go at it with a hammer as a last resort thats how **** gets fucked up even worse.
Old 12-16-2006, 06:36 PM
  #23
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
I can guarantee he didnt do it with the t-case still on
Old 12-16-2006, 09:34 PM
  #24
14 Second Truck Club
Does anybody have a link to the write-up? I looked and can't find it.
I got my grinder and ground it down the best I could. Couldn't grind it down too much because of the flywheel. I actually had to grind down a little bit of the block that was sticking out just to reach it. I got pretty close, but it was getting dark and called it a night. I take some pictures of it in the morning.
Old 12-17-2006, 10:09 AM
  #25
benvortec's Avatar
I have a 2000 2WD and I pulled the motor and tranny at the same time! Just did it like 2 months ago. And ironically enough I pulled it that way just because those damn TC bolts stripped on mine too! I just took the hood off, and eased the radiator support forward! It came right out, well with a little time and patience it did. But it's definately dooable.
Old 12-17-2006, 10:47 AM
  #26
High on diesel fumes
thunder550's Avatar
Au contraire
Old 12-17-2006, 11:29 AM
  #27
I finally got the damn converter bolt off, after 2 1/2 days of trying everything imaginable. I ground off a piece of the block that was blocking my grinder from getting up in there about 30min. later, the base of the head lifted up just enough to get a flathead screwdriver under it and hammered the rest off. I barely nicked my flywheel, but I think it'll be okay. What do ya'll think?
Old 12-17-2006, 02:51 PM
  #28
twobit's Avatar
Should be fine. Now get it out of there
Old 12-19-2006, 04:03 PM
  #29
Stroker2112's Avatar
....had the same problem (2 out of 3 stripped). I used screw/bolt extractors to get mine out...once you hear a "pop" (GM's locktite giving way)...they come right out.
Stroker2112
Old 12-20-2006, 07:56 AM
  #30
Hunt&Fisherator
silver-mod-o's Avatar
I hate that little tab on the block... what ******* purpose does it serve??? all I knwo is it gets in the damn way BAD...
-your flexplate's fine...
Quick Reply: Anybody strip a converter bolt?
