anyone ever buy from these guys
suburbazine, i got a quick off topic question you might have the answer to. my ecu is from a suburban and has a drop down option in the transmission choices which includes the 4l60e and the 4l80e when i use my hptuners. does this mean i don't have to do a segment swap on my ecu to run the 80e trans. just correct harness and option then tuning?
You can either run the 80E on the 60E tune with the correct harness modifications or you can get HPtuners Support to do a segment swap on your tune and use the ISS sensor. I don't know if the HPtuners software is able to segment swap correctly.
I went with Frost's 2 Relay Conversion Kit so I can keep my 60E tune. Plus it was a lot easier than doing harness work myself.
Baltimore Whore
The BMR people are nuts to offer that warranty on a 60E. Especially at that advertised HP/TQ.
I looked at their parts list and I looked at their warranty...while I think they are legit, I don't see how those parts will make a 60E live for 1 year at 750HP. Heck, I see no mention of input shaft or output shaft upgrades.
For what it's worth I did push my built 65e pretty hard and never had a failure. It's now a garage ornament.
now looking into converters, my current converter stalls at 2300rpm idk what it is since PO built the truck. im guessing i can stick with a stall around there and up for my cam. its a comp xer273. i'm assuming my best rout is to go with circle d but im wondering how this converter might do. would a circle d converter perform $200 better?
link
4L60 4L60E 4L65 4L65E 300mm 2500 High Stall Torque Converter | eBay
link
