Anyone have any Tranny install tips or tricks?
Just what the title says, was wondering if anyone over the years has come up with any tips or tricks to get the transmission started on the locating studs, I can't seem to get mine started on them, and honestly, it was starting to urk me a bit. Anything other than just keep f*<king with it until it falls into place?
Floor jacks, blocks of wood, and FRIENDS.
Take your time man. Don't force **** it in there! Wouldn't want to damage the pump.
Some kind of grease or lube on the dow pins
Hope that helps man
Hope that helps man
Baltimore Whore
A extra hand always helps( if they are competent). To get it start, or make like easier, I have always cleaned the **** out of the dowels, dowel holes on the trans, with a scotch brite pad.. Take your time, make sure everything is lined up RITE
![Grin](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_grin.gif)
I'm lucky enough to have a trans jack, it's doing a good job of getting in my way more than helping me out though.
![Icon Lol](https://www.performancetrucks.net/forums/images/smilies2/icon_lol.gif)
![Devil](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_devil.gif)
I'm running out of stuff to break! ![Icon Lol](https://www.performancetrucks.net/forums/images/smilies2/icon_lol.gif)
That was close, thought I was gonna get schooled on the search button, I already have the trans out though, just looking for tips on getting it started back on the dowels, because it's not playing nice.
My trans has a few more steps than that one does too.
![The Jester](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_jest.gif)
Don't listen to this guy ^^^
If you remove the pins then you run into possibly cross threading the holes on the block to mount the bell housing.
Man if you've never done it it will be a bitch and a half to get it right the first time. Its luck of the draw. with a trans jack however it should be fairly easy. you may have to tilt the motor forward or back to get the dowel pins to line up
