Anyone have to shim starter for Circle D flexplate?
Had this issue since the moment I got the truck running with the 80e. I need two washers between the starter and the block otherwise there is an audible whirring during cranking and with engine running where the flexplate rubs on the starter snout (at least I think that's where it's rubbing) I've tried 3 different starters, same result with each. Once I shim the starter down, the noise goes away.
LM7
2004 4L85e from a 2500 Suburban 8.1L
GM 15765623 inspection cover (irrelevant)
Circle D 2B converter
Circle D flexplate
LM7
Circle D flexplate
I have close to the same setup with the same tq converter.
I differ in that I have a TCI flexplate and have not needed shims.
Not an answer but a data point. I wish I knew more to help.
6kimages
41
02-07-2016 09:28 PM
2kta--89formula
01-12-2016 09:18 AM
