Assassin Traction Bars
#51
Does anyone have any measurements on this? My truck is 4/6 an im willing to go 3/5 just to run these if my truck has traction issues next year.
I run a factory 275/55/20 so its not like im on a rubber band but i will be running a 28-29" front runner with 28" DRs at the track. The more level my truck is the happier ill be
With the flip kit on 30in tire they are 5in away from the ground.
#52
Do you think you could get some pics up for us? Maybe some with a tape measure showing clearance and how low they hang from the front mount?
I've been doing some measuring and I have 5 inches of clearance from the bottom of the leaf spring up front to the ground. If that front bracket is smaller than 5 inches I should be good to go.
#56
11 Second Club
I hope no on takes this the wrong way or that I'm trying to sway you from buying these bars, but, if you're worried about whether or not these will work because of your drop, you're probably not going to get the most out of this product anyways. If that's your main concern, the cal-trac that you know fits, will probably work just fine
#59
And I'm worried about the front bracket hanging lower than my frame. I scrape my frame on things all the time and I'd hate to drag these too. But I think I'm going to be ok and I'm going to take a shot at buying them. If they hang too low I'll just have to sell them.
#60
My iphone sucks at night, I took the 5 pic's none of them in clear. I attached one at least this is the front mount.
Measurement are 5.5 in at front mount and diff mount was 5 in and keep in mind my truck is lowered 4/7 with 30in tires
