autotrac t-case from a 6.0/80E 2500
not sure what your asking . you want to run that t case on your 60e?
i dont think the 3/4 tons come with an autotrac case just a normal electronic selectable no auto feature's
as far as that case bolting up , no the 80e ane 60e have different output shaft.
11 Second Truck Club
Some 3/4 tons had the autotrac. Mainly 2500 avalanches, 2500 suburbans, and LD 2500's. If it is an np246 behind an 80e, it needs to have the output swapped to run with a 60e. You swapping the flt65e for an 80, or whats the plans?
I will probably swap to an 80e eventually.I'm just doing my homework.I wanted to make sure the 246 came with 2 different input shafts from the factory.One for the 60e and one for the 80e.
I know their is an output shaft for the 80e that can be used with the 60e/246 input shaft.
I was just hoping I wouldn't have to swap the input on my 246 if the 80e came from a 246.Sounds like I will unless I swap in the different 80e output shaft.I think their expensive though.
calsdad
06-14-2023 11:07 PM
FlowmasterMufflers
09-11-2015 03:32 PM
