Is AWD a GM option for any 2003+ Silverado?
Old 02-27-2005 | 10:50 PM
Silver Z's Avatar
Question Is AWD a GM option for any 2003+ Silverado?
An article in the latest GM High Tech Performance talked about mods for a 2004 Silverado 1500. They stated that the test truck had AWD, it was not a SS. Stated that AWD was a $300 GM option. I thought AWD was only available for the SS truck. Can anyone confirm this? Any links that have info on it. Anyone know the option code? Thanks
Old 02-27-2005 | 11:05 PM
nativetexan's Avatar
13 Second Truck Club
I thought it was just for the SS and Denali packages. I remember hearing that the awd option for the Denali was removed for this year. Also, $300 sounds pretty cheap to me.
Old 02-27-2005 | 11:14 PM
Silver Z's Avatar
That is what I thought but I am looking at the article now. It states that it is a $300 GM option for the silverado, I assume for the sierra also. It says you also have to option to turn off the AWD back to 2wd for dyno tests.
Old 02-28-2005 | 01:15 AM
SnakeOiler's Avatar
AWD means 'ALL' the time - this is what differentiates it from 4WD. To have something that turns it back to a 2WD sounds a lot like a 4WD truck to me.
I could not find anything about an AWD option on the Silverado. I looked on Chevy and KBB
Old 02-28-2005 | 01:23 AM
CHarris's Avatar
Just a AWD comment... supposedly the H2 is able to dyno with the front friveshaft removed and the transfer case set to 4 hi locked. The H2 doesn't have the viscuous coupling like the SS. If they offer a similar non-visuous t case it should work the same. I haven't tried it yet, myself.
Old 02-28-2005 | 12:08 PM
Cakes's Avatar
I think what the author was referring to was "Autotrac 4WD". As far as I know, there is no AWD option on any Silverado (its standard on the SS) Maybe I am wrong though but I am pretty sure. Maybe if you play the option codes correct it can be done (i.e. modern day COPO!)
Old 02-28-2005 | 12:12 PM
Scream's Avatar
MOOBIES Moderator
I've read the article, and the author was referring to Autotrac, which is NOT AWD. I think he just got his terminology mixed up.
Old 02-28-2005 | 12:42 PM
XLR8NSS's Avatar
Adkoonerstrator
Here is a thread the owner of that truck started. Read from post 58 on. It seems he just called the autotrac case an AWD case.
https://ls1tech.com/forums/showthrea...5&page=2&pp=40
The SS and Denali are the only GM trucks with AWD at this time that I know of. Is the Escalade available with AWD?
Old 02-28-2005 | 12:44 PM
Mr. Sandog's Avatar
Yes, it is. I know the EXT model is, anyway.
Old 02-28-2005 | 12:46 PM
leochevy2001's Avatar
Yes, the Escalade had/has the AWD option.
Quick Reply: Is AWD a GM option for any 2003+ Silverado?
