AWD swap guys. I have a question about locking the front end.
Hey fellas. I just finished my 4L80E and NVG149 swap into my truck. I'm planning on just locking the front end into 4hi. Well, I neglected to do so before I swapped transmissions and transfercases.
No I've got a "Service 4WD" error in the dash.
Can I lock in the front end by applying 12 volts to the solenoid? I'm not sure how to get it locked in now.
How do I make the "Service 4WD" go away?
Thanks!
Thanks!
Im not sure on the service 4wd. could be the xcase encoder?
But maybe look into the Warn 4x4 cable deal?
i cant rem what its called, but my cousin kept burning thru the thermoacuators in the front end. so he went with the warn manual lock for the front diff. it was more reliable.
i cant find it now tho
Well I've been doing some searches. From what I've read, it's probably not the wiring at the transfercase. It seems that the 4x4 buttons actually fail quite frequently. It may just be a coincidence that this happened.
I'm not 100%, but I don't think there were any lights on any of the buttons. That indicates a failure.
I'll take the buttons apart or at least wiggle some wires. I just need to engage 4 high so the front end is locked. After that I'll be taking the buttons out anyway.
I'd like it to be reliable enough to be a daily driver. But I don't want to have to rely on it. I've got a daily driver beat up neon.
Okay well I sold the problem with the front and not engaging. I just removed this part from my old transfer case.
Then I plugged it into my factory harness.
The next problem was the actual switch itself. I took it apart and I noticed that the solder had cracked where the plug meets the circuit board. So I resoldered it.
Then I turned the truck on and engaged 4 hi. I could hear it try to engage the transfer case. It also locked the front axle.
Next I unplugged everything. The plug on the front axle, the two plugs on the transfer case solenoid, and the actual plug-in the dash.
So the front end is engaged but I still have a service 4wd warning in my message center. I don't have any more time to mess with it tonight. I may have to jump some wires from plug the plug on the solenoid to get that light to shut off.
