AWD traction
AWD traction
I’m planning on running 500 crank HP and AWD
i have factory (govenor bomb) G80 rear. Should I upgrade to Eaton style rear differential.
If so, is anyone running the cheap “monkey grip” from eBay. LOL
also with only 500hp do you think I will need caltracs ?
RCSB if it matters…
RCSB if it matters…
Ha! I guess I respond to most of your questions. It just helps that I’ve been down the road you are headed towards!
The Truetrac may not be absolutely necessary, but the money you would spend on the Caltracs would be much better spent on the Truetrac on a 4wd/awd.
do you have a build thread ?
TEXASMADECHEVY
13
09-01-2007 02:39 PM
