B&M 28K GVW Cooler Ques.
I just bought a B&M Supercooler, the 28,000 GVW model. Only thing is that this is one of their "race" coolers that didn't come with any of the hardware to hook it up. It has 1/2" NPT fittings on it, so what do I use to connect it to the tranny? My truck didn't come with the aux. cooler that I could see but I'm assuming it doesn't since I don't have the towing package. It does have the lines that run from the trans to the radiator though so I was gonna run the cooler inline with the return line off the radiator back to the trans. Any ideas on what hardware and where to get it, or of any better ways to hook it up? I don't really want to shell out the coin for stainless braided lines and AN fittings.
TIA
TIA
You should just need some brass barbed fittings from any hardware store and some rubber hose rated to handle atf. I don't belive there is all that much pressure on the lines. I just got a Long Tru-cool cooler which is basically the same as what you got only mine is a little smaller and has a couple of barbed fittings instead of threaded fittings. I think it is actually made by the same company that makes them for B&M. Mine came with the barbed fittings and some rubber line. The parts store should be able to tell you what kind of line they have that will work I think mine is 3/8".
B&M Supercooler
Ordered the 24000 GVW SuperCooler last week. Received it today. Came with hose, brass fittings, brackets, looks to be a thorough install kit. Going to install it this pm. I'll post back this evening and let you know how it goes. Did yours come with the kit?
Install
Installed after work today. Friend took grill out for me. Used brackets supplied with the install kit, cut down with bandsaw to length. Installed directly below the latch assembly with hose fitting facing down. Installed in about an hour with a trip to parts store. Picked up an addition 3' of hose. Easy stuff.
Originally Posted by StrokerAce03
Awesome. Did you install it inline with the coolant line off the radiator or do how have a stock cooler?
Couldn't be easier. Really. Wish I would have done this 50k ago.
Vortec350ss
01-12-2016 10:36 PM
lxcoupe
09-25-2015 12:36 PM
