backspacing on 15" wheels
Old 01-28-2008, 02:45 AM
  #31
11 Second Truck Club
bluecajun5.3's Avatar
Originally Posted by slowprocess
Honestly....I'm just thinking about going with a set of 6 lug to 5 lug(5x4.5) adaptor plates(1.75" thickness) and going with a set of weld draglites with a 7.5 backspacing for track use only. I don't think it would be a problem running them about 5 times a month. Anybody see any problem with that type setup?
yeah i've been pondering this same idea recently using these...
http://cgi.ebay.com/ebaymotors/ws/eB...hippingPayment
rear:
15x10 draglite, 7.5 bs, 5x4.5
adapter plates 1.75" thick
mickey thompson et street radial 325/50/15
front:
15x5 draglite, 3.5 bs, 5x4.5
215/75/15 tire
any others have any input on something working like this?
Old 01-28-2008, 05:37 PM
  #32
sanger rat's Avatar
Will a 16x8 with a 5in back space clear the banjo bolt? I want to use these wheels. http://www.pacerwheels.com/shared_mo...=228&linkBig=y
Old 01-28-2008, 05:54 PM
  #33
yes, they should clear.
a stock 16x7 wheel has a 5.2" bs and +31mm offset.
so from this, you still have about an inch untill it would come in to contact with the bango bolt.
Old 01-28-2008, 05:56 PM
  #34
sanger rat's Avatar
Thanks, 2nd question. Would 285-60-16 fit on those wheels with a DMJ 4-6 drop?
Old 01-28-2008, 06:04 PM
  #35
maybe others with a 4/6 drop may chime in but with that tire size being 29.4" tall, i wouldn't think so.
Old 01-28-2008, 06:23 PM
  #36
oneslammedgmc's Avatar
[QUOTErear:
front:
215/75/15 tire
any others have any input on something working like this?[/QUOTE]
I realize that this setup will be strictly for the truck, but they will still stick out over an inch past the fenders won't they?
Old 01-28-2008, 08:19 PM
  #37
you mean just for the track? yeah, that's what they'll be for.
i just did a couple of measurments eyeballing it. your right, looks to be that they'll stick out around 1" past the fender. that's with taking into acount the 325's buldging out.
i think i can deal with 1" sticking out better than 2 or 3.
Old 01-28-2008, 08:34 PM
  #38
built408's Avatar
Ive had my stock 16 inch wheel widened 2 inches on the inside and have no clearance issues with hitting the banjo bolt... I guess cause i have suburban rear brakes the bolt is in a different location... Ill take some pics tomar of the rim and the clearance. Rims go perfect with 28x12.5x16 mt et streets..
Old 01-28-2008, 09:23 PM
  #39
SnakeOiler's Avatar
Originally Posted by Derek @ EDO
I will be, how wide you think i can go without clearance issues?
Think those tires will even fit under there.
You only have somewhere's around 12" under the fender to play with.
You could use a 12" wheel with 6.75" bs and should clear the leafspring, but..... it will stick out 2"+ beyond the fender. A section width of 14.8" is a lot of tire.
Old 01-28-2008, 10:07 PM
  #40
I don't know how low your truck sits but will you have enough clearance for the wheel/tire to stick out an inch and not rub on the fender lip when you launch off the line?
Quick Reply: backspacing on 15" wheels
