Bad Vibes Still
Old 09-26-2011 | 07:04 PM
07vmax1500's Avatar
you 2 or 4wd? you can get a vibe and noise from the front shafts. just a thought
Old 09-26-2011 | 09:37 PM
j_ahlheim's Avatar
truck is 2wd, no clips on brake drums I watched them be removed.
Old 09-26-2011 | 10:20 PM
Slammed96's Avatar
Because you are feeling the vibration through the steering wheel it means that it will be mostly coming from the front. If you only feel it in the seat and floor its from the rear and I would guess something along the lines of possibly pinion angle, tranny mount, or something may be loose. From the front I would check your ball joints by putting the jack under the control arm and raising the tire just far enough off the ground to fit a pry bar or something you can pry up on the tire with. then have a buddy bounce it while you check for play. I would also check your tie rods and wheel bearings while the wheels are up. That's about all I can think of that may cause vibrations. Hope it helps!
Old 09-27-2011 | 03:08 AM
Chevy-Fun's Avatar
try to find a speed that it vibrates, then let it coast in neutral, to see if the vibration goes away. If it does, problem is engine/transmission related. If not, look at the u-joints, axles & tires.
Old 09-27-2011 | 03:20 AM
Chevy-Fun's Avatar
In begins of yr had same prob was my back you joint. An then bak in august same vibration around 55-65 ended up replacing the front ujoint, yoke an drive shaft. Think ds was bad an also had sum wear on the yoke
Old 09-27-2011 | 06:44 AM
Vince B's Avatar
Jeff not saying that all of the info in this thread is not good. However I would look at when the vibration started and concentrate in this area. I honestly have not read all the posts/threads on your truck however as you know vibrations can be tricky. It is possible that with lowering a vehicle and the drive line angles being changed, that bushing wear in the transmission could be effected. In my years of building units I have seen some pretty worn out stuff so this could be an issue as well. Hope you get it figured out. Vince
Old 09-27-2011 | 07:29 PM
j_ahlheim's Avatar
guys thanks for all the suggestions but I had a guy buy the truck off me for a deal I couldnt say no to. I now have a 2012 Camaro SS to mod. Thanks again for all you guys.
Old 09-27-2011 | 10:41 PM
Slammed96's Avatar
man...I wish I could solve all my truck's problems by upgrading like that Enjoy the Camaro man, they're a blast
Old 09-27-2011 | 10:57 PM
bluebommer07's Avatar
2 degree shims ftw
RustyD
05-23-2016 08:04 PM
00loudchevy
12-03-2015 06:54 PM
dsbodley
11-14-2015 10:46 PM
lukn4trbl355
10-22-2015 12:19 AM
Chevy305
09-28-2015 10:21 PM
