belltech or mcgaughy?
Old 09-04-2008 | 03:56 AM
  #21
RotaryResurrection's Avatar
I'm curious to hear about the method you used to install your spindles, since you "know what you are doing" and everyone else here does not. And of course since there are so many different ways to bolt spindles on, I can see how you could sprinkle a little of your magic on top of your set and not lose turning radius, while the rest of us without your magic did.
But seriously...let's hear it.
Old 09-04-2008 | 10:13 AM
  #22
Mark Johnson's Avatar
THanks 006rcsb, I'm kinda over- committed right now with a set of 16" steels with winter tires and a set of 16" aluminum with a summer set right now..............
Old 09-04-2008 | 10:47 AM
  #23
trever1t's Avatar
2nd fastest 5.3 ECSB
Took the words right out of my mouth
The turning radius increased but not enough to make me want to try anything different. It's there and it's that but it's fine.
Old 09-04-2008 | 11:23 AM
  #24
flossinon_24s's Avatar
Originally Posted by Dezert1500
You won't lose turning radius with any of the drop spindles if you know what you are doing. I have the same turning radius I did when I was stock with my 2" drop mcgaughy spindles. I tested a couple sets and you don't loose turning radius.
dont you also have a regular cab? I think its just less noticable on the short wheelbase of the rcsb platform.
Old 09-04-2008 | 11:26 AM
  #25
Midnightrider's Avatar
2wd beltech 2/4 drop kiss your turning good bye unless you grind off the steering stops
Old 09-04-2008 | 08:55 PM
  #26
006rcsb's Avatar
i guess i could always just get a maggie and use my right foot to steer a little if you know what i mean...
Old 09-05-2008 | 01:26 AM
  #27
Dezert1500's Avatar
Sounded like that came off wrong to a few people. Didn't mean it that way. Anyway you need to find out what is limiting your turning radius. Then clearance according. It will be different for different drops. I'm at 6" drop in the front and it was really bad before I clearanced. I clearanced enough to get it back to stock turning radius. You should get 1 3/4 turns out of your steering wheel from center, left and right. For those that have drop spindles that is a good starting point to see how far you are off. Enough rambling here's some pics of what I clearanced. I clearanced the spindle slightly and LCA stops to make it mate to the spindle perfectly. I shaved some of the head off the bolts, so I ddn't have to shave as much on the spindle.
Before
After
Hope that helps.
Old 09-05-2008 | 02:25 AM
  #28
camarossls12001's Avatar
I did the mcgaughy's kit for 16" wheels on my truck but since added some 20" wheels Ball joints did not want to come out of the LCA's ended up using a blue tip wrench to get them out and just replaced them
Old 09-05-2008 | 10:48 AM
  #29
Ahh- so there's hope after all. The 16" 4wd spindles are looking better and better. Yippeeeeeeeeeeeeeee................
Old 09-05-2008 | 08:42 PM
  #30
006rcsb's Avatar
there are no spindles for a 4x4 truck that will fit 16 inch wheels. look them up if you dont believe me, i have because i wouldnt mind running a 16, but 17's are a minimum, and even those require the threads on the lower ball joint to be trimmed! im sure that if camarossls12001 used the 16 inch spindles he isnt 4wd.
