Belltech shackle adjustable?
I remember people talking about that but when I went to install the shackle 1 bolt hole down from the full "2" drop the flange was in the way. Do people trim that flange to change the drop from left to right?
Thanks,
Andrew
Thanks,
Andrew
I had mine adjusted 1 hole different side to side for a while. I am not sure what you mean by the flange being in the way. You should not have to trim anything. Maybe just flip the shackle 180* so the flange (?) is no longer in the way.
Andrew
my stock ones had the plate aka the flat part of the "c" facing the front so thats how I did the Beltech, using the top hole thou, I would think you could use the next lower hole if you put the open side foreward??? I didnt have instructions so I wouldnt know what Beltech says.
BCraven1018
11-02-2015 07:18 AM
