Best handling truck in all of PT.Net lets. Discuss
#31
i have a parallel 4 link with a pan hard bar with over the axle bags and it is a good set up although i think that the the double shear watts link is a better setup. also yes if you are going to try to make your truck stick a G' you need to get better weight distribution, stick the battery in the back passenger side corner (custom) and if you got the money you should stick a fuel cell between the frame rails like mentioned above. here is a link to my suspension build....http://www.crazytalkcustoms.com/projects-blake.htm
#32
Ive seen a few of those older Dakota RT's out on bigger autocrosses, haven't seen a truck on the track yet...
You'll want stickies, but finding them in an appropriate size would be difficult, but some 305 minimum width, on 18x10's could work wonders.
You'll need that front end in check way before you even touch the rear.
Progressive rate coilover springs in the front, along with some tuned shocks, fiberglass front quarter panels and hood, battery relocation would bring significant changes. You might even play around with ADDING weight to the rear to achieve a better balance.
An ideal setup would be placing your truck in a zone of neutrality. On the 200 ft, you attain ~1.0g while having the exact same throttle. You invoke oversteer only by touching the gas, and you bring understeer just by lifting a tad. Then you'd have a ridiculously good corner carver.
#34
Originally Posted by vanillagorilla
Are you guys talking about running panhard bars with leaf springs?
Porque?
Porque?
#36
the reason we are having this discussion is because its a truck and doesnt already do it, because we're at performancetrucks.net not slugtruckbodyroll.com (sarcasm noted not to be inconsiderate) i always find it difficult to find a panhard bar for our stock suspension but i dont know much about suspension so i guess thats my problem. i find all this discussion interesting and will definitly mark the thread for when i get to modding the handling!
#39
Originally Posted by Soon2bSpooled
a buddy has one of those, its fun to drive, but IMO i would rather have one of our V8's even though it runs high 14's low 15's stock.
Edit: Apparently the Taco has sub frames. The braces simply connect then together a little more ridged. Our frames wouldn't take advantage of them anyways.
#40
I wonder howmuch that taco weighs. I bet a little vehicle on big tires could take advantage of those tires.
There is also something to be said for matching swaybars that are engineered together.
I thought that a stiffer rear swaybar would allow the rearend to come around easier, negating other handling mods.
