Best place for Posi/Gear swap in Houston Area???
Like the title says trying to find the best place in the Houston area for my Posi/Gear swap. I wish I had the ***** to do the swap myself but just don't think I could swing it without F'in somethin up.
Pyle Bro's is really the only place I knew of, but they want $325 just for the install. I have all parts needed just need to find a good reputable installer.
Any help is much appreciated
Originally Posted by LS1TRUCKGUY
Give Exner Transmission A Call. They Are In South Houston. 713-473-0199. It Is A Good Buddie Of Mine. They Do Very Good Transmission Work As Well. Tell Them Jeremy Sent You.
I've heard of Exner before, never used them personally but I have heard very good things, mainly in the transmission business, didn't know they did rear ends too.
Also might want to try Pyle Bros in Baytown, again, have not used them personally but a ton of the houston area guys have. I know for a fact they are a top notch rear end shop.
Originally Posted by SlvrSierra4.8
Thanks for the info but as I said in my orginal post Pyle Bro's wants $325 just for the install. Which I think is freakin rediculous. They told me they normally would charge me $275, but since they could'nt make any money off of parts since I had everything it was gonna run me $325...
4-Wheel-Parts will not even install anything that they do not sell. The reasons for this is insurance purposes and them being able to send failed parts back to the manufacturer for credit back. It also insures that if they installed a gear set that fails due to an incorrect installation, that they could rule out it being the parts that someone else brought in to them.
There is a place in Sweetwater area that does specialize in only transfer case rebuilds and rear end gear rebuilds. I forget their name, but my brother did have his transfer case rebuilt their for his 01' GMC Z71. They offer a better warranty than you can get if he would have bought a completely remanufactured unit from GM.
I'll try and get their name for you.
Jim
Jim
Originally Posted by CHEVY6000VHO
Oh yeah, $325 is not too high either. If you ever try to rebuild one, then you will know why. It is not just a bolt out and in application. There are a lot of things that have to be shimmed, gauged, and adjusted just right or you will ruin a gear set in less than 5 miles.
Jim
Jim
I wish I only had to pay 325 for my gear and posi install. They wanted like 425 here for both....300 for gear only and IF i do it at the same time they were ONLY gonna charge 125 more for the posi.
