Best Slicks for a Truck, Look inside!
Originally Posted by F8L Z71
Because there are already a bunch of tires in the 26-28" range. For guys with 20" rims or us 4x4 guys having a 31-32" tall tire is perfect. Our stock rim/tire combo is about 31-32" tall and having a 27" tall tire would look silly AND throw off our calibration.
It also helps the traction impaired folks, turning a larger Slick allows 100" of Cir., 12" wide rubber to bite into
Originally Posted by 03silverado5.3
How wide is my stock rims I have an 03 2wd 1500 16'' alum wheel
This tire looks to be very promising, its just missing a price tag!
I think they should be white walls too. Now that's nastalgic!
Livin La Vida Goat
Did you ask them about "Slick Walk" with that tall of a tire on the big end of the track?
Anybody that has drag raced with slicks and Z rated tires up front knows what I mean.
I would think that slick that big would be a little sketchy with your street rated tires up front.I for sure would swap out the front 20's for the stockers when you track the truck.
Thoughts?
Thoughts?
Thoughts?
Thoughts?
https://ls1tech.com/forums/showthrea...=272264&page=2
Livin La Vida Goat
Originally Posted by moregrip
He described slick walk a tad and I think he has stock wheels up front.Your BFG's might be a little too grippy.
Just advise from drag racer to drag racer.
I would run your stock 16's up front.
I've searched google for slick walk, no go, what's the deal?
I'm not sure of the exact definition of Slick Walk but I assume it has something to do with mixing a bias-ply tire with a front radial tire and the wobbly, unsafe movement you get on the big end?
I noticed this in my T/A when running ET Streets and 17" Z rated tires up front. Not bad at low MPH but after 120mph and with only 10-12psi in the slicks things tend to get a lil "funny" up top and could easily send a newb into the wall if they start trying to correct for the side to side swaying.
I noticed this in my T/A when running ET Streets and 17" Z rated tires up front. Not bad at low MPH but after 120mph and with only 10-12psi in the slicks things tend to get a lil "funny" up top and could easily send a newb into the way if they start trying to correct for the side to side swaying.
I
