Best way to lower an 04 GMC Yukon XL
We bought a Yukon XL 2wd and I would like to lower it and see what people have used and seems to have rode the best and towed the best. I would like to run a 285/40/22 on it when the tires on it now wear out. What is the best kit and the most economical? Thanks
The front is a torsion set up and when you go 3-5 you have to cut some of the frame off where to bump stop mounts and I know my wife wont go for that. Are the kits that just use keys and coils worth a damn? I am thinking that maybe a 3-3 and then I can tune the rear springs with a little heat to get them where I want. I am not sure though I will pull some measurements to be sure.
EDIT-Just looked it up and you don't have to cut any of the frame off. It's purely bolt on.
Maybe... Is there any way to get them back to factory specs or atleast check to see if they are right?
I'd go with a bit more tire on a 22, something like a 305 45 R22. They would be much better for the ride and even more so if you plan on towing.
Originally Posted by RandomHero
You sure about that chief? I've never heard of that one before. I'm 99% sure that's not the case.
Originally Posted by 2001si3rr@
No cutting involved all bolt in like Hero said.
