Big PITA to get Tranny out?
Originally Posted by OnyxSilveradoSS
the top bolt on the bell housing will need your entire collection of extensions and a universal. we tried for about an hour till we taped the joint so it would not move as much.
For The Top Bellhousing Bolt I Used My 1/2 Impact With An 15mm Semi Deep Swivel On A 18inch Ext. Gets Em All Everytime. Ive Taken Mine In/out Seven Times. I Can Do It In Less Than An Hour By Myself If I Dont Have Broken Exhaust Studs,lol.
Originally Posted by 69Boss302
how do you release the TC?
you could do the fly wheel idea or just do what i always do and put a big 1/2 ratchet on the crank pulley and use that with one hand and use your air ratchet with a allen head to take the three tc bolts out. peice of cake.
A heat gun on the weatherpak connectors for a few seconds will soften the goo and allow the connectors to come apart without breaking. That shift selector switch is expensive!! Don't ask me how I know.
Dave
Dave
it can be done by one person, right? I watched the tech that did the first rebuild pull it out and it seemed really simple and not much different from other transmissions. Seemed almost as easy as yanking the C4 from my F-100 except this has some wires.
Am I wrong?
Am I wrong?
14 Second Truck Club
Am I wrong?
Am I wrong?
Dave
Dave
Totally disagree. It's much easier to just remove the 3 small bolts than risk breaking it. Take the 3 bolts out with an end wrench and set the whole thing aside.
