Black Transmission fluid
Old 02-03-2011, 06:06 PM
chris092183's Avatar
Default Black Transmission fluid
Anybody know what this means? I read that alotof guys getting their trans from junkyard or salvaged vehicles find black fluid inside. How bad is this? Does this mean the clutched are fried or that the trans got too hot? I'm concerned about bolting a new converter up and screwing it up if the trans is messed up.
Old 02-03-2011, 06:12 PM
2nd fastest 5.3 ECSB
trever1t's Avatar
Yeah, I'd be concerned as well. It certainly can't be a good thing
Old 02-03-2011, 06:14 PM
03sierraslt's Avatar
Sounds like some high heat and fryed clutch's. They kinda go hand and hand.
Old 02-03-2011, 06:17 PM
formerly b4vwannabe (2/4/2012)
badz24s's Avatar
If it's burnt up, at about the same time as you see the color, you'll definitely smell it. It will be very pungent to say the least. As far as black fluid, if you are junkyard shopping, check the fluid color before you buy it. If it's red & doesn't smell bad, you should be good. You should still change fluid/filter before you install a new converter.
Old 02-03-2011, 06:30 PM
02'Z71ONDUBZ''s Avatar
I wouldnt bolt a new converter to a tranny with black fluid, the black color is most likely clutch material.
Old 02-04-2011, 12:18 AM
what do you guy think if I throw the old verter back on with fresh fluid. Then cycle it for a week or 2 then remove old fluid and replace verter with new one as well as new dex 6.
Old 02-04-2011, 12:22 AM
KozzyJr's Avatar
if its black it burnt, the tranny over heated above 270 atleast to get it black. words of wisdome from an old fart if its black send it back!!!!! Not a racial comment either
Old 02-04-2011, 12:34 AM
dammit i just put a shift kit in it. so what does black fluid typically state went wrong besides high temp and clutches? Could other parts of the trans been screwed up too? What if I had all the clutches replaced?
Old 02-04-2011, 12:38 AM
I have a gauge for that
Atomic's Avatar
pump should be at least cleaned if not replaced, and valve body cleaned out...
Old 02-04-2011, 12:46 AM
I cleaned the valve body out very thoroughly. The whole pump needs to be replaced? Can't it just be sprayed with brake cleaner?
Quick Reply: Black Transmission fluid
