Bogarts ???
i went with 16x4.5s on the front with 15s on the back, iwould not get the welded ones for the simple fact bogart is a really light then metal which will bend rather easy this way if you mess up a rim you can just buy the rim and bolt the center hub in and be done, it beats cutting and grinding if a rim messes up..
my rears will be foresale soon as im getting another rear set with bead locks
I plan on getting a set made pretty soon.
Fronts: 17x4.5
Rears: 16x10
I decided on these wheel sizes because I drive my truck daily and want to keep the biggest factory brakes I can fit. The 05+ front brakes require a 17+ inch wheel and the factory rear disc require a 16+ wheel. My lowering spindle also requires a 17+ inch wheel which is another reason to get 17s up front.
Fronts: 17x4.5
Rears: 16x10
