BOOOOOOM!!! rattle rattle
Hunt&Fisherator
Stew, I have the same ORY, you can slide the trans over it and it will be out of your way. you dont have to cut it.... I had to disconnect my cooler lines.
use an e-z out for those converter bolts... I just had to do the same exact thing. not a big deal, just take your time.
Hunt&Fisherator
I disconnected mine from the trans but I'm sure you can do the same from up front... no biggie. You should be able to get an EZ out from any hardware store. it just so happens the shop I work at has a bunch of them laying around.
have you tried tapping the bolt remains out by turning it with a small chisel and happer??? or is it too deep in there?
Originally Posted by silver-mod-o
I just swapped mine out... its not too bad. its WWWAAAAYYYYYY easier to do on a lift though... I hear ya on not wanting to work on anything lowered... I know it sucks because I have the same damn drop LOL.
I dropped the d-shafts, x-member,cooler lines, and unbolted the TC and bellhousing and just slid the trans back over my Y pipe and swapped it out. I didnt have to drop it. if you can, the way I did it was a lot easier.
Hunt&Fisherator
Originally Posted by Beastofa327
What did you do to your tranny now?
Should only take you abought 3 hours to pull trans and reinstall ..I did the ball flanges on my Y pipe so it comes right out made it a lot easier.. pull crossmember let trans hang all the way down the motor mounts will stop it from going to far.. at that point all the trans bolts are very easy to get at ..And sorry for your bad luck but look at it this way it could had been you hiding in the bushes from the cops if the truck didnt break
How do I change this text
Damn, sounds like your not having too much fun pulling that trans...
I guess I don't get all this brokin flexplates... I've yet to brake one, hell I only had a three bolt 5.3 flex plate with the Art Carr torque converter, maybe I'm just lucky...
