Which brake pads to get?
Old 10-07-2005, 04:12 PM
SSlow 4.8's Avatar
thetirerack.com has them resonably priced @ $78 axle set for the front and $71 axle set for the rear
http://www.tirerack.com/brakes/brake...ads&perfCode=P
and they are a sponser
Old 10-07-2005, 05:21 PM
Originally Posted by shadowamker
No I mean 8500. I ve made 2 trips to the mountains pulling 4 atvs. A few of the hills, I could smell the brakes getting hot. I m assuming thats what did them in. Thinking bout going with slotted rotors too. Wheres a good place to get Hawk brake pads?
Brad
Well getting out of the temp range for the pads will kill them quick. Thats the beauty of performance pads like the Hawks, they can operate at higher temps. Perfect for mountain drives and towing.
While your at it since you know you are heating up the system, you may want to bleed your brakes, and/or swap to SS lines if budget allows. But at least bleed your brakes with some ATE Blue fuid. Flush out the stock stuff till the blue comes out
Old 10-08-2005, 01:37 PM
SS Crew's Avatar
You've got at bumper to bumper warranty for the first 12000 miles - they should honor that.
I got over 150,000 mile on the brakes on my '99 ecsb - never had them off or had the rotors cut. I'd step up to the factory pads again. And they don't throw dust like the ones on my wife's BMW.
Old 10-12-2005, 06:56 PM
kitronic's Avatar
Default Brake pads
I've tried many pads over the years and I recommend; Performance Friction pads for tow vehicles.
Higher coeficient of friction (less pedal effort) and work better the hotter they get. Reasonably priced as well, similar to OEM $.
Use your search online, many companies sell them.
Good pads
Old 10-12-2005, 11:35 PM
RoninsDenali's Avatar
EBC greenstuff for the win!... its what i run and i've never been happier...
Old 10-13-2005, 08:33 AM
Bish's Avatar
Good pads
In the past, I have run a few sets of Performance Frictions and agree that they get better the hotter they get. I really liked the performance when warm. I tried them on my Tahoe about 100K ago and they only lasted about a month. What I HATED about them is their cold performance. I could be driving down the highway, have somebody pull in front of me and have NO brakes for the first second or two until they got hot, then they would grip like no tomorrow. That first second or two would have me wondering if I was really going to stop. Other than cold performance, they were great.
Since then, I've been a convert of Praise Dyno brakes and I am on my second set or pads/rotors x 4.
Old 10-29-2005, 01:04 AM
Destroyer of Transmissions
1SlowHoe's Avatar
Are the pads for the front and rear the same? For my Tahoe I cant find a rear set of Hawks. Only front pads but they say "Performance Street Compound, Front Pad Set, With Rear Disc, 1 Set Required Per Axle." Sounds as if the pads will fit both front and rear since I have read discs. Anybody know?
http://www.partsandaccessories.com/a...=12&brandid=42
Old 10-29-2005, 01:14 AM
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
Get the Hawk HPS series they are the best IMO. By the wording on that description I would think you would need two sets of those. I thought the rear wwere different but maybe not.
Old 10-30-2005, 03:11 PM
fluxu8's Avatar
My rear brakes are squeaking pretty bad with only 34,000 miles on the truck.
RustyD
05-23-2016 07:04 PM
turbo6c3
10-05-2015 06:11 PM
KINGCYCLES
10-02-2015 10:21 AM
Noah Burns
09-13-2015 09:28 AM
Quick Reply: Which brake pads to get?
