Brake rotors, wtf?
Old 05-16-2010, 10:07 PM
sbw9056's Avatar
Originally Posted by Mrgoodwrench3
I have seen this a lot on trucks that are in snow climates. It is very important to lube the sliders and bolts so the calipers can slide smoothly. The pistons need to move freely and there should not be any rust or debris where the brake pads mount.
When I replaced the front pads I cleaned and lubed the pins.
I will check them tomorrow.
Do you think that the brake and ABS lights I am having are due to this odd brake wear problem?
Old 05-16-2010, 10:11 PM
Mrgoodwrench3's Avatar
The ABS light will set a trouble code. Most common problems are wheel speed sensors. I would say the lights are not related to abnormal wear.
Old 05-16-2010, 10:16 PM
sbw9056's Avatar
I pulled out my trusty Harbor Freight code reader and it did not show any trouble codes.
Old 05-16-2010, 10:17 PM
Old 05-17-2010, 03:06 AM
PT's Slowest Truck
budhayes3's Avatar
Crappy factory rotors, mine did the same thing. I had the rotors replaced under warranty and the new set did it too. Replaced them myself with some aftermarket "performance" rotors, and they're still going strong some 7+ years later
Old 05-17-2010, 05:18 AM
HuskerZ71's Avatar
Mine were just like that only five times worse. I replaced them with OEM rotors and what a huge difference. I cant believe I didnt drive up someones *** before.
Old 05-17-2010, 05:15 PM
Silverado53's Avatar
How does your brake fluid look? Is it full? I've seen the lights come on just from low brake fluid. Are your brakes noisy?
Old 05-17-2010, 07:20 PM
sbw9056's Avatar
I was not able to check my truck today. I will check it out tomorrow and post up what I find.
Old 05-17-2010, 08:27 PM
MikeGyver's Avatar
My factory rotors did it, too. I cleaned them up on a brake lathe, and they did it again. If EBC makes replacements, that's what I'm getting. My mom's Cobalt did the same thing and I replaced them with EBC, they're great now. It must be some awfully crappy metal that GM used.
Old 05-18-2010, 05:16 PM
sbw9056's Avatar
I pulled the rotors off today. The pads were only making contact with half of the rear side of the rotor. The fronts were a little better at 2/3 clean contact area. I can't believe I didn't have braking problems.
Until I get new rotors, I sanded the old ones down. They will work for now.
Here are some pictures.
http://i945.photobucket.com/albums/a...tors/Front.jpg
http://i945.photobucket.com/albums/a...rs/Back2-1.jpg
http://i945.photobucket.com/albums/a...ors/Back-1.jpg
http://i945.photobucket.com/albums/a...tors/Edge2.jpg
http://i945.photobucket.com/albums/a...tors/Edge1.jpg
http://i945.photobucket.com/albums/a...otors/Pads.jpg
http://i945.photobucket.com/albums/a...tors/Pads1.jpg
http://i945.photobucket.com/albums/a...Frontafter.jpg
http://i945.photobucket.com/albums/a...ackafter-1.jpg
http://i945.photobucket.com/albums/a...rontafter1.jpg
Quick Reply: Brake rotors, wtf?
