Brand New 4l60 and ABS problems???
Old 11-08-2010 | 08:03 PM
Goose33's Avatar
Default Brand New 4l60 and ABS problems???
Hey guys first off let me say long time reader first time writer on here. I just installed a brand new 4l60 in my DD truck took old one out put new one in no problems but now my abs kicks in at low speeds like stopping at a stop sign or something then every now and again the "service brake system" comes up. Is there a sensor or something I can check to get this to stop? Is this common? Otherwise everything is great on it the new tranny has 350 miles on it and this only problem I have had any suggestions would be great. Thanks in advance
Old 11-09-2010 | 07:58 PM
Goose33's Avatar
Any ideas?
Old 11-09-2010 | 09:17 PM
viciousknid's Avatar
Where's the Beef?
Does your speedometer look like it twitches or anything? Could be a faulty VSS (Vehicle Speed Sensor) on the tailshaft.
Also try to clean the ABS sensors on the front hubs.
Old 11-09-2010 | 09:43 PM
Goose33's Avatar
Yes it does actually I thought it was just my unsteady for bc I left the Y pipe off fr a lil while just bc of sound haha
how would I go about fixing the VSS
Old 11-10-2010 | 07:38 AM
FLT's Avatar
FLT
FormerVendor
Goose I posted on your other thread on tech. With you having issues with the vss I can see where this might be a problem. Make sure you connections at the transfer case is solid. Pins and wiring would be what you need to look at. If all this is fine and the problem still exists then try swapping in another sensor. Vince
Old 11-10-2010 | 05:53 PM
Goose33's Avatar
Thanks Vince I'm goin to check it out tomorrow I think my transfer case connection is good put I might try swapping out with another vss
Old 11-11-2010 | 01:39 AM
04BlackMagic's Avatar
i'm sure a cam header package would fix the problem haha maybe a tune
Old 11-11-2010 | 10:45 AM
Goose33's Avatar
maybe not fix it, but even when tranny was out still out run the that black P.O.S! haha
Old 12-05-2010 | 11:51 PM
Goose33's Avatar
hey just wanted given a long over due update that the VSS wasn't screwed in right but everything is ok as of now been running real good..i appreciate the help you guys gave me..saved a lot of time
Ken in AZ
09-17-2015 08:08 AM
Fast86z
08-23-2015 01:35 AM
97aztecgt
08-13-2015 03:11 PM
lo&sloSierra
07-19-2015 11:56 AM
