Broke level 3 Performabuilt 60E
Old 11-23-2008, 04:10 PM
2ktransam's Avatar
Default Broke level 3 Performabuilt 60E
Well I broke my tranny this week. I was stalling it against the convertor and heard a clunk then I had no reverse, no nuetral and park was grinding. I swapped the tranny out this weekend and it's going back to Performabuilt this week. The crappy thing is I am out of warrenty by 2 months so I have to pay $950 to get it fixed. Hopefully they can make it stronger or I will just break it again.
Old 11-23-2008, 04:15 PM
Baltimore Whore
Mangled03gmc's Avatar
That sucks, I am sure they will make it right.. I take it this is the truck in your sig?
John
Old 11-23-2008, 04:17 PM
GMCtrk's Avatar
For all the money you spent, you could have gotten a bone stock 4l80e that is stronger than any built 60e. If one can get a good condition 80e for $1000-1500 I don't even see the point of buying a built 60e which costs more and will blow up anyways eventually.
Old 11-23-2008, 04:32 PM
2ktransam's Avatar
John
Yeah, this is the truck in my sig.
Old 11-23-2008, 04:36 PM
2ktransam's Avatar
They guarantee their level 3 for 800rwhp in a car so I was hoping that it would hold in my truck at 600. If or when it breaks again I will have to go 80E but I was trying to stay away from all of the change over stuff.
Old 11-23-2008, 04:39 PM
GMCtrk's Avatar
I haven't looked at it all too much, but I'm thinking when my 60e pops, 80e is the best way to go. It is cheapr in the long run. I don't think there is any 60e that will hold 600rwhp. FLT lvl5 holds up to 500rwhp I think is what they rate it at. With your turbo LQ4 I think usiing a 60e may be futile!
Old 11-23-2008, 04:48 PM
no title here
skyhighsami's Avatar
What you don't realize is that the 80 gears are long as hell, and it robs more power. I have both and I prefer the way the 60 feels, but I know the 80e is much stronger
Old 11-23-2008, 04:56 PM
kbracing96's Avatar
That sucks man, Everyone likes to talk about the 80 swap, but they are all 2wd guys and don't realize how much more of a PITA it is in a 4wd. Luckily when my built 60e broke a couple months ago, it was just a twisted off output shaft and I was able to fix it myself.
I have decided to do the 80 swap next spring and am gathering parts, but even going though the trany myself with new stock clutches and seals, TG shift kit and using a remaned stock Converter, I'm still gona have $1000 in the trany (paid $350 for it but needs gone though), $600-700 in drive shafts (needs about 2" shorter in rear and 2" longer for front), probably another 500+ in convention parts, (input gear for t-case, flexplate, cooler line extensions, lower bell housing ect.) plus a LOT of labor. And if I wanted to get a good converter, that's almost another $1000. Not as easy or cheap as all these guys make it sound who are 2wd.
Good luck with getting it fixed, Hope PB takes care of ya!
Old 11-23-2008, 05:04 PM
2ktransam's Avatar
Originally Posted by kbracing96
That sucks man, Everyone likes to talk about the 80 swap, but there are all 2wd guys and don't realize how much more of a PITA it is in a 4wd. Luckily when my build 60 broke a couple moths ago, it was just a twisted off output shaft and I was able to fix it my self.
I have decided to the 80 swap next spring and am gathering parts, but even going though the trany myself with new stock clutches and seals, TG shift kit and using a remaned stock Converter, I'm still gona have $1000 in the trany (paid $350 for it but need gon though), $600-700 in drive shafts (needs about 2" shorter in rear and 2" longer for front), probable another 500+ in convention parts, (input gear for t-case, flexplate, cooler line extensions, lower bell housing ect.) plus a LOT of labor. And if I wanted to get a good converter, that's almost another $1000. Not as easy or cheap as all these guys make if sound who are 2wd.
I love how every body says that it's an easy swap but yet Speed inc's kit cost close to $5k with the level 5 tranny and you still have a ton of labor on top of that. If it was cheaper I would have done the swap in the first place.
Old 11-23-2008, 05:22 PM
kbracing96's Avatar
ME TOO!!!
Quick Reply: Broke level 3 Performabuilt 60E
