Broke level 3 Performabuilt 60E
Old 12-05-2008, 10:57 PM
  #71
kbracing96's Avatar
Originally Posted by 2ktransam
Just bought a billet output shaft.
That was a good choice!
Old 12-05-2008, 11:33 PM
  #72
2ktransam's Avatar
Got it for $300.
Old 12-06-2008, 10:32 AM
  #73
built408's Avatar
Good move!!! It will save you ALOT of money in the long run...
Old 12-06-2008, 10:53 AM
  #74
kbracing96's Avatar
Got it for $300.
Was that the one in the classifieds a while back? I almost bought it, but decided to just put the money toward the 80e swap that I don't want to do,
Old 12-06-2008, 10:55 AM
  #75
2ktransam's Avatar
Yep, that's the one I got. I am going to try and stay away from the 80e until later next year.
Old 12-06-2008, 07:08 PM
  #76
11 Second Truck Club
Breeze's Avatar
Originally Posted by silver-mod-o
What kind of power are you making?? I know mine has been living with 600 or so at the crank without a hiccup.... Soon to be closer to 700 with more boost.
Back then about 500 and the 65 worked fine untill that one Day
Old 12-07-2008, 11:15 AM
  #77
Zoojelly's Avatar
They guarantee their level 3 for 800rwhp in a car so I was hoping that it would hold in my truck at 600. If or when it breaks again I will have to go 80E but I was trying to stay away from all of the change over stuff.
Guarantee of 800 hp in a car is different than moving a heavy truck, These trucks with serious HP need a level 5 design especially the way you like to drive it
Old 12-07-2008, 11:35 AM
  #78
2ktransam's Avatar
Performabuilt's level 3 is considered the same thing as a level 5 from other companies. Same components just a different number.
Old 12-07-2008, 12:08 PM
  #79
LS1TECH & Trucks Sponsor
performabuilt's Avatar
I would like to once again make clear this transmission did not fail for any power related cause, It failed due to a faulty molded piston allowing fluid to leak n the forward clutch eventually resulting in the failure of the forward clutch friction, The rest of the transmission was perfect , No signs of shafts twisting broken parts or slipping clutches .everything else was cherry in the unit.
Old 12-08-2008, 03:03 PM
  #80
ILuvJDM's Avatar
are the 65e/70e transmissions a direct bolt in for a truck that has the 60e stock?
Quick Reply: Broke level 3 Performabuilt 60E
