Broke level 3 Performabuilt 60E
#82
LS1TECH & Trucks Sponsor
Yes however the 70E is not stronger than the 60e, The notation 70e simply means it has and input speed sensor where the 60/65e does not . When a 70e is placed in a 60/65e vehicle there is no wiring for the input speed sensor so its ignored , however you cannot replace the 70e with the 60e because those trucks require the speed sensor. You can of course swap the pump /input shaft and harness to do it but what would be the point
#83
#84
A 70E does not mean it has an input sensor. Where do you guys get this? The 60/65/70E all have the input sensor now. The 70E is a 65E with a different output shaft. You won't find a 70E behind a 5.3L or 4.8L, but you will find a 4L60E with an input speed sensor.
#85
From bulletin: 05-07-30-026
General Motors Powertrain required a version of a current production rear wheel drive transmission capable of handling higher torque and horsepower without going to a larger size transmission. As a result, the 4L70-E was created. Very much like the 4L65-E, the 4L70-E shares many of the same components and adding premium materials and additional manufacturing processes, the 4L70-E is capable of handling up to 400 horsepower and 430 foot-pounds of torque. It is also capable of increasing shift speeds up to 6000 rpm.
The 4L70-E will be first introduced in some 2006 mid-size sport utilities and full-size pickups. The 4L70-E will be identified as RPO M70. The M70 will use the large 300 mm (101K or 112K) torque converter. Some M70 models will be the first 4L60 series transmissions to receive the new input speed sensor (ISS) .
Below are the 2006 4L70-E applications and models:
• Sport Utility 4L70-E models with ISS: SKD/TKD
• Full-Size Pickup 4L70-E models: CMD, CWD & KMD
The following identifies the 4L70-E (M70) components and the components it shares with the 4L65-E (M32) transmission.
Item Number
Part Description
ID Feature
RPO M32
RPO M70
(Picture below)
300 mm/112K Torque converter (1)
• Identification code label affixed to the convert cover
• Outer diameter & lug size
X M32
X M70
5-Pinion input carrier Asm. (662)
Number of pinion gears
X M32
X M70
7-Plate 3-4 Clutch Asm.
(7 friction, 6 steel plates)
• Number of friction plates
• Steel & apply plates have "HD" stamp
• Friction plates have Identification stripe
X M32
X M70
5-Pinion Reaction Carrier Asm. (681)
X M32
X M70
Reaction Internal Gear Asm. (684)
3 machined grooves
X M70
Output Shaft (687)
One identification band
X M70
HD Low and Reverse Roller Clutch Asm.
Bronze clad cage
X M32
X M70
Input Sun Gear and Forward Sprag Asm (642)
Paint marking
X M32
X M70
Input Turbine Shaft
X M32
X M70
Stator Shaft
Darken splines
X M32
X M70
Another informational post from GM
Subject: Automatic Transmission Model Codes Equipped With or Without Input Speed Sensor
Models: 2007 GM Light Duty Trucks and Utilities
Equipped with 4L60E, 4L65E or 4L70E (RPO - M30, M32 or M70) Transmission
Identifying 4L60E, 4L65E and 4L70E transmissions equipped an input speed sensor. Vehicles that use an ISS are not identified by vehicle, only by transmission code listed below. The transmission code can be found on the transmission case or in GM Vehicle Inquiry System (VIS) under the Vehicle Component page
2007 models that WILL use ISS
7CFD
7SBD
7TFD
7CLD
7SFD
7TKD
7CVD
7SJD
7TLD
7KFD
7SKD
7KLD
7SLD
2007 models that WILL NOT use ISS
7CAD
7CWD
7PCD
7CAB
7KAD
7PKD
7CHD
7KCD
7SDD
7CJD
7KMD
7SZD
7CMD
7KZD
7TDD
7CSD
These are pretty much types of vehicles with the ISS.
2006-2007 Buick Rainier
2006-2008 Chevrolet Trailblazer
2007-2008 Chevrolet Avalanche, Colorado, Silverado, Suburban, Tahoe
2006-2008 GMC Envoy
2007-2008 GMC Canyon, Sierra, Yukon, Yukon XL
2007-2008 Hummer H3
2006-2008 Saab 9-7x
Equipped With 4L60E, 4L65E or 4L70E (RPO M30, M32, M70) Automatic Transmission
It's pretty much any with the new style pcm.
Item Number
Part Description
ID Feature
RPO M32
RPO M70
(Picture below)
X M32
X M70
X M32
X M70
X M32
X M70
X M32
X M70
3 machined grooves
X M70
Output Shaft (687)
X M70
Bronze clad cage
X M32
X M70
Paint marking
X M32
X M70
Input Turbine Shaft
X M32
X M70
Stator Shaft
Darken splines
X M32
X M70
7CFD
7SBD
7TFD
7CLD
7SFD
7TKD
7CVD
7SJD
7TLD
7KFD
7SKD
7KLD
7SLD
7CAD
7CWD
7PCD
7CAB
7KAD
7PKD
7CHD
7KCD
7SDD
7CJD
7KMD
7SZD
7CMD
7KZD
7TDD
7CSD
2006-2008 GMC Envoy
2007-2008 Hummer H3
2006-2008 Saab 9-7x
#86
If GM was really out to upgrade the unit they would address those issues, I have seen no more failures with the 4 pin than the five so from my perspective it was not a significant upgrade, Have never really seen any substantial number of failures with the 4 pins as long as they had lube. And without that both planets will fail in short order.
#87
I can see your point, but to actually call it a 70E because they don't know the difference just isn't right. It confuses others wanting the correct info. No offense meant, just trying to help get correct info out there. I'd be checking the codes on the trans from your supplier to see if they are really giving you what you ask for.
The 65E and 70E all should have 5 pinion planetaries. If they don't then you probably got an incorrect core. The 65E and 70E has held up to fairly big power in stock form with just a shift kit and converter change. The biggest improvement with the 5 pinion GM (not cheap aftermarket replacements) is the metal. They are a much higher quality than that 4 pinion version. The true GM one's are high quality and very, very rarely fail. The clutch sets in the 65E and 70E hold up much better than the 60E. I've never replaced a broken input shaft on the 65E and 70E due to them being hardened, but have replaced many broken drums where the shaft presses in. The 60E's I've replaced them for broken shafts and drums. I've also never replaced a sunshell in a 65E or 70E yet. The beast sunshell is very nice and I've never seen one of them break, but the 65E/70E one seems to be very strong also. The output shaft on the 65E is is hardened, but the 70E version is hardened with a different process and is even stronger. I have the info from another bulletin somewhere.
lukn4trbl355
10-21-2015 11:19 PM
Wrecker 426
09-30-2015 09:39 PM
