Broken 80e!
Old 06-23-2011, 07:23 PM
  #21
Vince B's Avatar
Originally Posted by smokeshow
The transmission is going to need a rebuild. After seeing all the debris in the pan that wasn't clutch material and pulling that junk out of the converter, theres no telling what else is lingering around in there.
I think thats a very good idea to go through the unit. I would agree with Chris that you had a bearing failure. Then again its pretty obvious with the stuff you are pulling out of the trans. I would say that the converter was failing and that is where your temp problems started. Vince
Vince B is offline
Old 06-23-2011, 09:14 PM
  #22
bud8fan's Avatar
[QUOTE=smokeshow;4723051]I'm probably going to buy a converter from Circle-D, probably a 2B triple disc.
i had a 3b first but was blowing thru it so he tightened it up to a 1a and im very satified with it...
bud8fan is offline
Old 06-24-2011, 03:10 PM
  #23
Mod with training wheels
smokeshow's Avatar
Pulled the trans apart, made some discoveries...
Direct clutchpack
Intermediate clutchpack
Chewed up intermediate clutch
Burned intermediate steel
Little abrasion on the band
The pump looks pretty good...theory busted
OD clutchpack looks ok...this is the worst one
Forward clutchpack
Burned up forward steel
Called the local transmission parts supplier, got a price on some kolene steels and red alto clutches for the forward, intermediate and direct clutchpacks, along with a rebuild kit. Hopefully I can get them today and possibly have the trans back together this weekend. Will have to wait about a week on the converter, though.
smokeshow is offline
Old 06-24-2011, 05:31 PM
  #24
Laid Back
Beatdown Z's Avatar
Bud8fan and Jake, how many miles were on your Yank converters when they failed?
Beatdown Z is offline
Old 06-24-2011, 09:04 PM
  #25
smokeshow's Avatar
I bought the converter from Nicksilverado...he didn't know the mileage, but said it was working fine when it came out of silver-mod-o's truck. I only put 3-4k miles on it.
Have a Circle-D 2B multi-disc on order...$1100 later
Old 06-24-2011, 10:26 PM
  #26
bud8fan's Avatar
i think mine was around 10-12k
bud8fan is offline
Old 06-25-2011, 01:10 PM
  #27
Laid Back
Beatdown Z's Avatar
Alright, so we'll just say silver-mod-o put 5k on that verter, bringing the total up to 8-9k. My PI failed with about 18-20K on it, and bud8's with 10-12k.
Seems to me that 8-10k would be a good time to pull the converter and have it freshened up. What you guys think?
Old 06-25-2011, 02:11 PM
  #28
11 Second Hall Moniter
AKlowriderZ71's Avatar
That seems a little ridiculous to me. Are all of these failures the same type of failure, or are different internal parts crapping out?
Atomic, was your trans a fresh build, or did you install it used?
AKlowriderZ71 is offline
Old 06-25-2011, 03:28 PM
  #29
Nicksilverado's Avatar
I believe ben= silver-mod-o had about 1000 miles out of it. so it lasted through 2 turbo trucks that both put down 600+hp . BUT circle d is the beez neez.
Nicksilverado is offline
Old 06-25-2011, 05:25 PM
  #30
I have a gauge for that
Atomic's Avatar
Both my 80es were fresh installs; one straight from performabuilt, and the other a fresh rebuild.
Atomic is offline
Quick Reply: Broken 80e!
