Broken 80e!
#51
That code, along with defaulting into 3rd gear only, is likely a tuning issue. Take a few minutes & read all the way through this thread.
https://www.performancetrucks.net/fo...ighlight=p0752
There are a couple of DTC's you must disable if you have an aftermarket "looser" converter installed. If you don't, the PCM thinks a shift was not completed(target rpm didn't occur), so the PCM throws the tranny into "limp" mode, which is 3rd gear only. If you drive on it much in 3rd only, you'll smoke the clutches, especially if you have good hp/tq.
HTH
Roger
HTH
Roger
#52
Ok, it turns out I can't set those DTCs to no error, since they aren't even in the DTC list. I checked a few other Gen4 GM vehicles, and they are lacking those codes on the list as well.
Assuming it is a tuning issue, that wouldn't explain the gnarly noise coming from under the truck prior to the shift. I ordered the shift solenoid from Orielly's, should be here tomorrow.
#53
11 Second Hall Moniter
That's true about the noise. One time my 60E pump made that noise, pressure gauge went crazy while making the noise (needle rattled way up & down, sounded like a woodpecker inside the transmission), builder had to tear it down & reassemble it. He never admitted to finding something wrong inside, but he fixed it.
I don't think the shift solenoids will changed anything. Pretty sure you'll be taking it back out to be torn back down. But I also think you have a tune issue.
#54
#56
I wish I could give you a good answer on that.
Here's what I know about automatic transmissions, in a nutshell. They need 2 things to work properly. The ratio needs to be absolutely correct, or it will not work correctly. I still don't know the ratios, but the parts list includes black-magic, and voodoo. If you have too much, or not enough, of either one, you're screwed.
That said, it's my professional opinion that your transmission has too much black-magic, and not enough voodoo. I hope you get it solved soon.
#59
#60
Alton he's been fishing and then made a trip to Joliet for the NHRA nationals! Jake I guess when you drop the pan to replace the solenoid we will know if the trans is coming back out or not. With the noise you've got me worried because of what we have seen the last couple times the pan has been down. If you find some crap in the pan I want you to do a couple things before you pull the unit. Save the oil or do this before dropping the pan. I want you to pull the rear cooler line to check for flow and also the tail housing to make sure that the rear case orifice is spraying oil for the rear housing. I'm concerned that there is a lube issue here. I will say that it has been my experience that 80's do heat up much faster than the 60's and will run a little hotter. In your case we keep seeing issues with hard parts is why I say this. Vince
