Broken 80e!
#81
Everything that came out went back into the 80e, minus the seals and whatnot, they were replaced with new stuff. The right cooler line fitting went back in. As far as the pushlock connectors are concerned, they are identical. If anything is different, it would have been that fitting on the inside.
#87
While I was driving the truck to a trans shop today, I found that I do in fact have 4th gear. Only one thats missing is 2nd; it has that clicking sound the whole time the HPT scanner says its in 2nd gear. After I got there, he told me to unplug the transmission harness connector to make it default to 2nd gear, but it only gave me 1st. Hooked it back up, and put it in manual 2nd with the shifter...truck moves. I guess the band engages in manual 2nd to hold the drum so it still has the gear technically, but since the clutches aren't engaging for whatever reason, putting it in D makes the trans skip over 2nd gear.
His diagnosis...lugs are broken in the case and the clutches aren't engaging evenly so it doesn't feel like it has 2nd gear at all. That would also explain all the steel shavings I found in the pan a couple nights ago...chewed up steels. OR it could be a torn up intermediate sprag.
As for the overheating, we brake stalled the converter to 3500rpms in both reverse and 1st gear and it didn't even need to get into boost. The dude said that excessive stall rating on the converter could cause the overheating, which I believe is a possibility. But I really think it is overheating now for the same reason it was before, whatever the reason may be...
#89
Probably not the case on a 4L80E.
Too harsh of a 1-2 shift, excessive intermediate clutch clearance, or improper burnouts are the normal cause for failure.
