broken pumps
Old 08-09-2011, 07:15 PM
Former Vendor
Circle-D's Avatar
I suggest to have the converter looked at. The hub may be damaged and the top rounded off and not engaging in the converter good, even though the clearance might be good. I would also suggest a billet rotor.....
Chris
Old 08-09-2011, 08:21 PM
bad cutt's Avatar
I have used the same bell. I am using the original flexplate . The pump has been replaced not rebuilt. I sent the converter to tci to have them go through it. Where can I get a billet rotor for the pump
Old 08-09-2011, 08:59 PM
Vince B's Avatar
I personally would swap in a new flex plate and a new bell. Try to set your converter clearance to .125(1/8") and see what happens. I'll be honest here I'm not a big fan of TCI stalls and have seen some sick run out on them. However in your case you have broke pumps with two different converters.
Old 08-09-2011, 09:10 PM
bad cutt's Avatar
The converter got sent out to tci yesterday. I will try to check the runout when it comes back
Old 08-09-2011, 09:17 PM
Vince B's Avatar
Keep in mind you want to do this by looking at the pilot and the hub. When I have done this in the past I have chucked it in a lathe.
Old 08-09-2011, 10:06 PM
bad cutt's Avatar
I have no access to a lathe I can't think of another good way to check it
Old 08-09-2011, 10:34 PM
PT's Slowest Truck
budhayes3's Avatar
Hey Vince, Gil, and Chris, do you feel that it would be worth bad cutt's time to see how much thrust that the crank has while he's in there?
Old 08-10-2011, 06:09 AM
Vince B's Avatar
Absolutely. That is something I would have think he would have already checked after the first couple pumps.
Find someone that does and tell them what you have been going through here. Askl them to make sure its correct.
Old 08-10-2011, 07:23 AM
FormerVendor
Gilbert@Ace Racing's Avatar
Vince is absolutely correct in suggesting that you have the hub runout checked on your converter. Vince you might be on to something regarding the dowels and overall alignment. If the pump is not centered the it will take out the pump for sure.
When this pump comes out can you get us some good pics of it disassembled? We might be able to see something that will lead us to the problem.
And most defininitely the crank thrust needs to be checked as well.
Old 08-10-2011, 12:38 PM
bad cutt's Avatar
I can text or email pics
Quick Reply: broken pumps
