Broken Transmission... suggestions?
I was trying to pull the transmission, I think I'm going to just put a housing on and try it before I pull it, have an extension housing on the way. But I have a stall converter on the way as well, so I'm eventually going to have to pull the transmission anyway, and I'm having problems pulling it, the top stud and cooler lines specifically. I searched the forum, and I tried coming in from the back with several extensions, and I couldn't get it to budge that way, so I've started unbolting my intake, also the cooler lines are so damn tight that I couldn't get them to budge in the limited room I had.
4' 3/8" to 1/2" transmission extension works wonders
13mm and 15mm are your nut and stud sizes. for the bellhousing. you can go from the top by pulling the intake but seriously a pita for just 2-3 bolts. the cooler lines comes loose when you take the E style clip out of the fitting and pull them out. i use a very small flat head to do this or you can spend the big bucks on a tool that rolls it out the way for you
I know, I'm going to swap the housing, and bolt everything back up, and put some miles on it first just to make sure, but then I'm going to run into this problem again when I go to pull it for the stall, so I figured I'd ask the questions now instead of wait until I'm stuck again.
gmcyukon
10-03-2015 11:03 PM
