Built rearend questions..
I personally never ran RP, but I have lucas, so that has worked well for me.. The master instal kit comes with new shims, bearings, you will need to do the install.. You can get away with using the stock caps on some cases but i used all the **** that cam with the Master kit..
John
John
Baltimore Whore
LSD will transfer power back an forth on the tires, depending which one is spinning more, or with less traction, posi is both wheels all the time with power.. Get a tru trac, be done
John
John
There are clutch type, wedge cone things that break type, torsen (trutrac), and locker. The locker is the only type with positive engagement which means once it locks nothing is going to slip. The clutch types are good, eventually might need a re-build. The torsen is not meant for drag racing but holds up good anyway.
