Built tranny shift question~1-2 shift killing me
Before I installed a "built" tranny I had a tune that beefed up line pressure. My tuner gave me this info "Commanded PCS line 'amperage" at WOT is under 0.10 amps which will command over 185 PSI"
The new tranny however, has the accumulators blocked off. So I'm wondering if the raised line pressure combined with the accum. being blocked is the reason for my neck breaking 1-2 shift at partial throttle? I live on a clay road and if I go slow (under 10 mph) the 1-2 shift is so harsh it actually activates the traction control because the rear wheels break loose. I can see the digs in the dirt after I roll a few more feet. People actually hold thier drinks until after I shift to 2nd 'cause they don't want to spill them Needless to say this is annoying. At WOT the shifts are great. Any ideas? Anybody nearby with software to adjust this? I have no software at all.
Originally Posted by OCBC
From my understanding, you should have stock line pressures with any shift kit.
Or at least start with the stock settings, then modify as desired.
I returned my tranny settings to stock (from Magnuson's beefed-up Radix settings) right after installing my shift kit, and before driving on it. As of right now, I am still driving on the stock tranny settings, and they are fine.
Shift kits are made to work with the stock transmission programming.
Originally Posted by 02sierraz71_5.3
is it vacumm modulated or do the stock electronics still control line pressures?
I just got my tranny built, I believe from the same place you did based on a brief converstation we had a week ago and mine does the same thing. The 1st to 2nd shift is a killer under light throttle. I had firm shift settings on my VHP tuner prior to the tranny build, so I am wondering the same thing.
Some builders go with a vacuume modulator if that is the case you can adjust line press with a flathead.
If not set the force motor table to STOCK and adjust the 1-2 shift under upshift pressure modifier
this is the table I ended up with and it works well for just a trans go shift kit
-7 -7 -6 -4 -1 0 0 0 0 0 0 0 0 1 2 5 6
-7 -7 -6 -4 -1 0 0 0 0 0 0 0 0 2 4 6 7
-7 -7 -6 -4 -1 0 0 0 0 0 0 0 1 2 5 7 8
-7 -7 -6 -4 -1 0 0 0 0 0 0 0 2 3 6 8 9
-7 -7 -6 -4 -1 0 0 0 0 0 0 0 2 4 7 9 10
