Bullet Proof 4L60E...?
Old 07-17-2010, 09:49 PM
00_Hotrod's Avatar
Default Bullet Proof 4L60E...?
About a month ago I started Managing a transmission shop and now i want to build me a stout 4L60e trans and a 2500 stall.. I can build it myself but i dont know what some of the best parts are, Anyone know what some of the best parts are that can be put in one of these to make it pretty stout..? sun shells, drums clutchs ect.. and where i can get them..?
Old 07-17-2010, 11:20 PM
fredkj3's Avatar
finishlinetrans.com
Old 07-17-2010, 11:21 PM
fredkj3's Avatar
300M billet input shaft
300M billet output shaft
FLT machined performance pump
Media blast case, bell housing, and tail housing to restore a new aluminum finish. Prep case for assembly.
FLT sleeved input drum
FLT (billet 6061 aluminum) overrun piston
FLT beast shell kit w/bearing kit
GM 5 pinion input carrier
GM 5 pinion reaction carrier
Bearing style reaction shaft
New reverse input drum
Alto wide 2-4 carbon lined band with reinforced anchor
8 B/W hi-energy clutches w/koleen steels in 3-4 clutch
Extra Wide Heavy Duty double caged 29 element sprag
4L65 low roller clutch
Transgo HD-2 shift kit
Corvette Servo
Sonnax super hold 4th servo
Bushing kit
New solenoids
New Internal wire harness ( If needed on 4L70E )
New GM Spacer plate
B/W clutches
Seal & gasket kit
Filter
GM deep pan
Updated aluminum accumulator pistons
FLT prepped valve body w/ HD 2-3 shift valve modification
Set end play to FLT specs
Case cooler fittings
Old 07-18-2010, 09:32 AM
2BFAST's Avatar
Corvette Servo
Bushing kit
New solenoids
New GM Spacer plate
B/W clutches
Seal & gasket kit
Filter
GM deep pan
Good list here. Only thing I dont agree with is the B/W clutches. Which im assuming you mean Borg Warner??? Alto reds or Raybestos blues is what you want. The blues being the better of the two but more pricey. Also why replace the reverse input drum?? I can see if there was excessive wear due to the 2/4 band, but if there is even wear thats nothing a brown cookie wont scuff up. Your thoughts?
Old 07-18-2010, 09:55 AM
454navyss's Avatar
Originally Posted by 2BFAST
Your thoughts?
i think we need more pictures of the woman in your avatar
Old 07-18-2010, 12:38 PM
stevenc's Avatar
that is FLT's list and they have a good reputation with their setup. I would trust it.
Old 07-18-2010, 07:24 PM
built408's Avatar
Only hack builders use "brown cookies" to "scuff" things up. And alto reds aren't a great choice for 3-4's.
Old 07-18-2010, 07:48 PM
2BFAST's Avatar
lol, guess im a "hack" builder. Your reason for not using reds for the 3/4?
Old 07-18-2010, 07:58 PM
05RST2NV's Avatar
How much hp is the finishline level 4 trans good for??
Old 07-18-2010, 09:25 PM
11 Second Truck Club
MPFD's Avatar
To put a horse power rating on a transmission is foolish. A N/A 500 hp motor is not going to put the same wear on a trans as a motor that makes 500 hp on spray, nor will a 500 hp turbo'd engine have the same characteristics as either above. FLT makes the best tranny on the market how long it lives is up to the use and driving habits of the owner...
My FLT has to contend with high 300 hp levels 90% of the time and low 500 hp levels 10% of the time. I'm not saying that I'm being easy on it, but it's not like I have 500-600 hp on tap like the FI guys. Thats why I like spray. But at the same time, when I leave the line I'm dropping the hammer on near 700 ft/lbs. Where a turbo'd car leaves softer and the power comes on in the R's. There are too many variables to put a HP # out there, like performajunk....
Quick Reply: Bullet Proof 4L60E...?
