Burnt trans fluid but tranny shifts fine?
Former Vendor
Check cooler flow to make sure there is not a restriction. Should be about a quart in 15 seconds. Pull the return line and start it up, it's a 2 man job. I would also put a scanner on it and watch for TCC slippage, make sure it is fully locked up. One more thought, where is the trans temp located? The best place is in the cooler line going to the radiator, this is the hottest reading you can get. If you have a great cooling system, it might cover up a slipping problem by the time it gets back to the pan. Good luck.
Chris
Chris
Chris
Chris
I've just watched his temps on hptuners and it has never been higher than 180 and it only got up that high in stop and go heavy traffic in the middle of summer.
Where's the Beef?
stock 4l60 I believe comes with 5. The one i had built for my blazer has Raybestos Z-PAK with 13 clutches. and I think the builder that did his had 7 Borg / Warner .065 hi energy frictions 3-4 clutch
Well i guess once it goes she will be getting a new tranny/rebuild. I doubt he is gonna have it torn apart just to see for now. I can at least tell him what you guys think the problem may be though, thanks!!!!
![Nod](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_nod.gif)
