Cal-Tracs??
Cal-Tracs??
im considering getting caltracs on my truck with the flip kit. but im been hearing that they call caltracs the clank tracs which they are noisey. that within time they get loose. but what experience do you guys have and performance on them.
THey have had that set out for some time. A couple of years ago I ordered a few sets and one of them I ordered for had a flip kit, actually, I think it was 2 of them.
Anyways, they are noisey, and they will make the rear suspension very stiff if you leave them loaded. Leaving them loaded is the only way to make them semi quiet though.
A easy fix to the noise is removing the link bars when your daily driving it.
That's what I did. It's easy and mine has been noise free for over a month and a half now. Yes the 3/4 rubber hose trick works, but like stated above, it will wear through. It's very easy to replace if you insert the bolts from the outside in before mounting the leaf eye up to the hangers. Then you can replace the hose section whenever you want.
I've been thinking of what to use that would allow a nylon tube to go over the bolt. That would last a lot longer.
The bars will only be put on when I go to the track or if I get a wild hair or something like that......
Jim
Jim
