Cal-tracs and drop hangers...
So what's it take to make it work? I found bluecanjuns' thread when he had it like this but the angle on the bars looked too extreme to be right...I know it worked well for him, but he still eventually changed it up.
With the drop hangers, what would it take to get the bar more parallel to the ground...short of doing a flip kit. Surely someone has done this and can give me some insight. Thanks
11 Second Truck Club
a flip kit is the only way i know of.
with the drop hangers, it puts greater angle on the bars than with the stock ones since it is being relocated higher up on the frame.
if your striving to get lower in the rear, txsilverado at one time ran 3" drop shackles. you can also remove the overload spring for more drop and they work great like that with the caltracs.
On my dakota i have 2" blocks in the rear and had to remove the helper spring to get them on. The angle opn them isnt to bad. I have no problems with them at all, and have found that they helped my 60ft times to be very consistant. They make my truck launch a whole lot better.
