Caltracs Vs. Sway bars
Saying "Caltracs Vs. Sway bars" is like comparing apples to oranges. One system is for controlled body roll while the other is for planted traction during hard acceleration. You have to recognize they are two completely different systems and they can't be put up against one another in a battle. Do you want to go around turns fast or do you want to prevent traction loss during stop light races? The simple answer is both, but if you're asking "Caltracs Vs. Sway bars" as if asking which one to install first, only you can answer that based on what it is you use your truck for most.
Considering the specs on your 4.8L, lowered center of gravity from the dropped suspension and the simplicity of installation, I'd go after sway bars first and traction after.
![Icon Confused](https://www.performancetrucks.net/forums/images/smilies2/icon_confused.gif)
I dont care if they're 'intended' for full throttle launches.. How does physics not tell u that better planted back wheels would help with cornering? I said I have trouble with wheel hop in hard turns. I shoulda wrecked my truck one night over it. Maybe its just me but it would seem that caltracs would only benefit cornering and compliment the sway bar nicely for cornering and also help traction on launches. Just me I guess.
caltracs have been my favorite mod so far. they made the biggest change in the performance of my truck. are you getting wheel hop or wheel chatter under hard cornering? chatter will be helped by sway bar (less body roll). less stress on the outside tire. cal tracs will not help body roll , but will prevent spring wind up(wheel hop). if you are spinning under power while cornering and getting "wheel hop", than caltracs will help.
I've been thinking between the two which would be more beneficial for the rear end. I know traction isnt a huge problem for me but I do have some problems especially cornering. Would Cal-Tracs help with cornering as well as traction or would both Cal-Tracs and a sway bar be necessary? Im lookin to get the best of traction and cornering
+1.
ok saying that, tell me how it wouldnt pan out to put cal-tracs on for cornering if its supposed to plant the rear wheels better...?![Icon Confused](https://www.performancetrucks.net/forums/images/smilies2/icon_confused.gif)
I dont care if they're 'intended' for full throttle launches.. How does physics not tell u that better planted back wheels would help with cornering? I said I have trouble with wheel hop in hard turns. Maybe its just me but it would seem that caltracs would only benefit cornering and compliment the sway bar nicely for cornering and also help traction on launches. Just me I guess.
...I'd go after sway bars first and traction after.
Caltracs are for straight line fun. Launch improvement will help 60' & wheelhop. I have wheelhop in straight line, but it's less now w/ sways. But then again, I did the whole TVS setup at once.
![Grin](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_grin.gif)
![Lurk](https://www.performancetrucks.net/forums/images/smilies3/lurk.gif)
Shakes, u are one of the few I've seen running both. 00Silv4.8, if u do the Hotchkis rear springs, I've been told it's necessary to use a different front bushing to coexist w/ Caltracs. I'll find out when I order.
![Secret2](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/secret.gif)
good info everyone. I know what they're both intended for but it would just make more sense to me to be able to go ***** out in a turn with both. I have noticed wheel hop under power in a turn and thats what kicks the *** end around. I am pretty set on both now. I know its not cheap tho
![Sad](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_sad.gif)
James
good info everyone. I know what they're both intended for but it would just make more sense to me to be able to go ***** out in a turn with both. I have noticed wheel hop under power in a turn and thats what kicks the *** end around. I am pretty set on both now. I know its not cheap tho ![Sad](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_sad.gif)
Dewey, u r also running a s/c, w/ NOS. At 11.7, a bit more power is being put down by you.
Build for the future my friend. Think of how much it'll help when u add more.
