Can a 2wd 4l65e be converted to a 4wd trans??
Old 08-16-2010 | 06:40 PM
eddie_da_chevy_guy's Avatar
Exclamation Can a 2wd 4l65e be converted to a 4wd trans??
My buddy has 01 silverado z71 and his trans went out and he can get a good 2wd 65e out of a 06 for half the price the trans guy is charging to rebuild his original..... He wants to know if its posible to use the 2wd drive and convert to 4wd...... What all is involved can he do it or does the trans have to be tore down???
Thanks guys.
Old 08-16-2010 | 06:58 PM
budhayes3's Avatar
PT's Slowest Truck
The output shafts are different so it basically has to be torn down
Old 08-16-2010 | 07:04 PM
kbracing96's Avatar
Yep, guts have to come out to get to the snap ring that holds the shaft in. It's not a bad job, I've done it a few times, but pretty intimidating for someone whos never opened up a tranny.
Old 08-16-2010 | 07:11 PM
ok so it would have to be taken in to a trans shop.... So something a trans shop should whip up pretty cheap and quick?
Old 08-16-2010 | 07:35 PM
kbracing96's Avatar
If there not crooks. I called a couple and they wanted to charge me $1-200 and a gasket/seal kit to do what took me 20-30 minutes to do myself. the only gaskets that "could" have been replaced were the pump gasket and the pan gasket, I just reused them on mine.
Old 08-16-2010 | 08:50 PM
silverz28camaro's Avatar
I swapped out the output shaft in my 4l60e from a 2001 camaro to fit my 4wd ram.
Like everyone else is saying, its not hard, just have to know what your doing.
Gasket and seal kits are cheap, shouldn't need nothing more then that. If a shop would do it for $120, it wouldn't be a bad deal.
Old 08-17-2010 | 02:38 AM
anybody in socal/ la/sfv area know any good tranny shops that can do this?? I will make some calls tomorrow morning.
Old 08-17-2010 | 11:58 PM
01 BERGER CAMARO SS's Avatar
a friend of mine converted my dads 2wd to 4wd with new seals, band, filter and parts for 160...i though it was cheap
Raggedz71
07-29-2016 11:20 AM
bighouse
09-27-2015 01:37 AM
cams 98 silverado
07-31-2015 08:36 AM
KyleW707
07-29-2015 09:17 AM
85SS/85GN
07-22-2015 01:48 PM
