Can the 4L70 handle no TM?
Originally Posted by 2004Denali
OK let me put my .02 in. I thought the 4L65E was just a beefed up 60E from the factory and the 4L70 was just a beefed up 4L65E. if that is correct anyone that has a level 4 or 5 60 or 65 is probably already better than the 4L70. I could be wrong and probably are.
Mark
Mark
The changes from 60E to 65E are well-known, and they're documented right here.
Originally Posted by tblrk1980
From what I gather, the only different part is the input drum. I have heard that the unit holds more fluid and handles higher temps.
That thing about more fluid...curious how that's possible if the outside dimensions are the same as the 65.
have you messed with your PCM on your TBSS? Remove the TM?
Originally Posted by TBSS
No, but there is a company in Michigan tuning TBSS's and doing work in the ECU as well as the TCU. I haven't decided which way I will go yet, canned tune or HPT/EFI. I want this vehicle to be something I'm not going to be messing with all the time.
